protecting the base of timber fence posts
23 Jun 2006
Hi guys,
I've installed wooden fence posts as I much prefer the look of them to concrete, they allegedly pre-treated but following advice on here I stood them in a trough full of Cuprinol Preserver for a week and gave loads of thick flowing coats.
Now they're planted in place, I was going to use a 'Ducksback' type fence paint and paint them again - my thinking was the preserver as the base treatment which penetrates the wood, then the ducksback type stuff over the top to protect - its oil based I think?
Anyway, seeing as they rot off at the base where it meets the floor I was thinking of doing 1 of 2 things.
1) apply some waxoyl (the stuff used for cars) as its very good for repelling water. Could this damage the wood in any way as its designed for metal/car use?
2) Alternatively, some kind of decking oil?
Whats the best thing to do?
Thanks!
Ducksback is a waxy emulsion stain. When fresh, it throws rain off without wetting the wood. The makers claim it lasts 5 years. I don't think it will do any good underground or in standing water as I presume it is breathable.
I recently treated some outdoor timber with linseed oil (do a search) and am rather pleased with it. It soaks in and repels water. The first few coats are thinned with white spirit to help them soak in. i don't know if the white spirit will displace your cuprinol - try their help line if you are using anything unusual.
My shiplap cladding is cuprinol clear, then several coats of waxy stain, which is very easy to recoat.
see //www.diynot.com/forums/viewtopic.php?t=60257&highlight=shiplap
You can apply the linseed oil without white spirit if you heat it, or apply heat to the wood afterwards. Best is to dip in 150 deg C oil, but that's a bit difficult for occasional use. (This doesn't make it "boiled" linsed oil)
