I'm renovating the kitchen and installing new wiring with a separate ring main for kitchen. The double oven and hob have yet to be chosen, so I'm trying to provide for every possibility and future proof at the same time.
I plan to run 2 separate cables to 45A DP switches (or CCUs) from CU, as advised by spark - one each for electric x2 oven and an electric hob. The only practical site for the switches is either in the brick wall on the other side of a window about 1.5 metres away or in a plasterboard wall about 1.8 metres away.
Can I run cables from the switches in the wall and go under the worktop behind floor cupboards to outlets in the cupboard near to the oven or should I run back up the wall from the switches and over the ceiling to outlets somewhere behind the oven?
