I have a Mira Thermostatic Mixer shower valve which is very stiff to turn on and off. If I turn on the cold water tap at the sink first, the valve will turn easily. I have therefore concluded it is a water pressure problem.
The problem has worsened since I had a new supply to the house installed to fix a poor flow rate in the supply.
I have conflicting advise as to the best solution, either a pressure reducing valve inserted in the cold feed to the shower, or a mini expansion vessel.
Can anyone shed some light as to which is best and why?
