Thanks for all the replies re my last post about extending a boiler flue through a conservatory roof. That now seems sorted as the conservatory company have their own Gas-Safe fitter who will do this as the conservatory is built, but before this I would welcome guidance on this one please.
I need to re-route the PRV outlet so it exits to the outside of the intended conservatory. It`s now about 1.4m from the ground.
Are there regs about the outlet point re the height from the ground and accessibility, and is there good practice for this?
The conservatory side walls will be about 125mm from the garden fence on each side so no access there, or I could run it down and out to the side. The advice of the conservatory installer is to run it down to ground level as it is now and across the patio some 3.2 mtrs (conservatory will be 3m) and when they dig out the footings for the concrete they will sheath it in the concrete and it can exit the floor beneath the new intended conservatory door step, this will leave it only about 50-80mm from the outer patio ground level, but it will be accessible.
Does it also need to be "kicked back" as I`ve read about elsewhere on this forum, and what`s the reasoning behind this?
