Hey all
Checked all over and can't find the answer to my problem so here is my thread.
This morning I noticed that my old pullcord had broken and wouldnt turn into the on position. I bought another pullcord (Almost exactly the same one) and wired it up. Problem is it wont turn the fan on? The light on the switch lights up when in the on position and goes off when on the off position. The switch has locations for earth, positive and negative for "feed" and "switch". I have tried the cables in every combination possible just in the event that it woul work.
Strange thing is that when I turn the light on in the loft and leave the pullcord in the on position the fan turns on so I can deduct that it is working.
The way the circuit appears to be is:
-Power cable running to a plug socket
-Power cable from plug socket to switch for fan/pullcord circuit (this has power as the light is lit)
-Power cable from plug socket also going to a switch for loft lighting. If I flip this with the pullcord in the on position the fan sometimes works :S:S:S
-Power cable from plug socket for fan/cord to a circular box.
-From circular box it connects to the fan and the pullcord.
-The wires to the pull cord are simply a pos, neu and earth.
-In circular box there are 2 of each wire (cant remember exactly)
I can get pictures in the morning if that helps? This thing is driving me fooo king crazy
