Hello
I’ve recently moved to a flat which has a pulsacoil 2000 boiler fitted in an airing cupboard. Next to the cupboard are two switches marked “normal” and “boost”. When I put the “normal” switch on, I have no hot water coming out from the taps, even when it has been switched on for 24 hours i.e. through the off-peak period where the water is heated. In fact, when I put the “normal” switch on, the green light at the boiler does not illuminate, and I hear no noises at all from the boiler.
When I put the “boost” switch on, the green light at the boiler illuminates, and I get hot water and everything works fine, however I think this means I’m not making use of the off-peak “normal” mode and paying much more for electricity.
I don’t think the issue is to do with power supply via the “normal” switch, as I have checked the power distribution box, and the power switch for the “normal” switch is on. Also, the orange light at the switch illuminates when I switch it on.
A bit more information which may/may not be of help:
- When I first moved in, both switches were off, and when I switched them both on, I still had no hot water, until I topped up the plastic tank above the heater
- Sometimes, when I switch the “boost” on, the green light at the boiler doesn’t illuminate, and it doesn’t switch on, until I just put my finger on the green light/switch and it miraculously turns on
Any advice/ideas will be appreciated.
