Hi folks,
I've just checked through the old posts and couldnt find an identical one so will post my problem here, although I've a feeling (or I'm hoping) it could be a simple solution....
Just moved into a recently built (rented) flat with a Pulsacoil 2000 system. The first 4 weeks the system has been working okay, hot water when we want. The past couple of days the water has been tepid at best in the morning, until this morning when it was completely cold. However even when the water was tepid in the morning, we have maaged to get hot water during the day for a bath for the nipper.
The main heater switch is on, the off peak switch is on, the booster switch works as we used it a couple of days ago. The green light is on on the boiler front, the red light is off.
Not entirley sure how the system works, will I be needing to look at the off peak circuit??
Thanks in advancve.....
