After the hot water tap has been turned off, the boiler makes a few creaking noises then the pilot goes out. This happens every time the water is turned off.
If it isn't changed quickly your AAV will blow steam out like a kettle and can cause damage to the boiler and surrounding area, unless you want a kitchen with a steam facility fella
