Hi there,
Firstly what happens:-
1.my sister comes home from work and switches on CH.
2.Water kettles up and then dumps the CH water out the PRV.
3.Low pressure LED on as you would expect.
Jobs already completed on the boiler:-
1.Re-pressurised the CH Expansion vessel to 15psi.
2.Replaced CH water pressure swicth (Old switch destroyed last time the water was dumped!)
3.Replaced PRV.
4.Replaced DHW flow Switch.
Possible fault now causing this (my ideas!):-
1. Pump impeller damaged/intermittent rotation from cold
2. Blockage somewhere
3. Wax diverter valve faulty (sticking in Hot Water mode)
Other notes:-
1. Boiler has been working fine for over a week.
I have not seen the fault occur as it only seems to happen when the boiler has been switched off all day and then re-lit at tea time.
Does anyone know what else goes wrong in this common boiler??
Please help! I'm losing my hair with this!!
Thanks,
Matt
3.Replaced PRV.
Other notes:-
Thanks,
Matt
