S
steve h
have had a recent problem of no c/h only hot water i changed the overheat stat and this solved the problem only to create another.
now i cannot turn heating off by timer or the small switch for (con.off.timer) when i turn the timing clock to check and see if burner goes out nothing happens unsure how old boiler is, at present we are using boiler temp.contol to keep heating on, then using stand by to switch off.any ideas anyone
