Hi all,
Long story but will try to keep it brief!
Recently our Puma 80e started making kettling noises. We called out the Direct Line people (who cover our boiler) and they said the heat exchanger was full of lime scale. Direct Line said this was not covered!
I then added Fernox DS40 to the system, and within an hour everything was working well. Within 4 hours, there was water pouring from the bottom of the boiler.
Direct Line let us down again so I fixed it myself... It was the 22mm isolating valves and an O ring on the CH water temp sensor all leaking.
Left the remainder of the DS40 in for the remaning time as per instructions. Drained, flushed lots and added the neutraliser for 2 hours.
Drained and flushed again, added Fernox Inhibitor. Everything was great.
Left the auto air valve on top of boiler open to remove last of air.
This was over a week ago!
I am having to top the boiler up every other day with around 0.5 bar pressure to maintain around 1.0 bar cold.
I have exhausted every avenue I can think of and cannot find any leaks anywhere, yet that amount of pressure is more than just a few drops??
I have checked:
The pressure relief valve - it did stick when I used it to drain the boiler, and was the prime suspect. I cable tied a clear plastic bag over the pipe - not a drop has entered the bag in 2 days - not even condensation.
Pipework & Rads. Unlike the boiler, these were all replaced just over a year ago - most of the pipework is the flexible plastic type except from the boiler and onto the rads. No visible leaks - even checked when cold to avoid evapouration.
Last night once the system had gone cold I shut the isolator valves and went to bed. This morning when I got up and opened them, the boiler pressure dropped indicating the pressure in the pipes and rads had fallen...
So, why can't I find any evidence of leaks? I would say I am having to add a pint of water (or thereabouts) every day. I still hear small amounts of air in the odd rad, but can't believe this is all going out of the auto valve?
Sorry it's a little long winded for a first post and I guess I know what the reply is going to be....
I have checked:
