My Problem -
my boiler appears to be kettling.
Someone has suggested that the kettling has been caused by either poor circulation ie. pump problem, or by overtemp in the boiler pipes caused by faulty cut out on the boiler thermostat.
Have looked at the pump - it is quite hot compared to the temp of the pipes, the pump appears to be turning, and makes a normal humming sound suggesting normal operation.
Have looked at the thermostat on the boiler - when turned to the lowest setting it operates normally - boiler turns off so i dont think it is a faulty thermostat.
I am inclined to think that it is poor circulation.
can anyone shed any light on what might be causing the kettling, or how to check the efficiency of the pump
i have a stelrad ideal wlx boiler, fully pumped vented system, and the pump is a grundfoss. i have also just replaced the zone control valve and refilled the system with fresh water.
