- Joined
- 4 Nov 2004
- Messages
- 3
- Reaction score
- 0
- Country
Hi, would appreciate any info on a rather strange problem one of my customers has. The pump cavitates, or in other words, gets inundated with air. This was the situation as of last night. Initial problem was upstairs rads quite warm, downstairs cold. 1st thoughts would be pump, right? Right! Changed pump, worked well for a few days then gradually went back to pre new pump. I'm thinking air lock now, so fiddle with the pump and rads for an hour or so to release the air lock. Things better but not as expected. Hmm! (Scratch head), fully drain system and fill again. System drains like a dream and fills even better. Hmm! Hmm! (More head scratching) Can't be airlocking if the system fills that quickly. Anyway, I run the system cold until the pump is running with a gentle hum. Fire up the boiler, primary flow heats up PDQ and the pump starts to cavitate. Right now you're thinking kettling, right? Wrong! Boiler is running whisper quiet. So now I'm thinking maybe need to power flush as there could be a blockage on the primary return, but it doesn't seem to fit the bill. Any suggestions would be most welcome
