I have an Ideal Classic FF280 boiler based system. I had to drain the system to remove an unwanted radiator from the system and now it is now struggling to restart. There is a continuous low frequency hum from the motor, even with the boiler switched off. If I restart the boiler it occasionally fires up for a few seconds before stopping. This same thing happened about two years ago, the last time I drained the system, but it started to work again after 12 hours.
Does this indicate a likely pump fault?
