I've just moved into my new flat and notice that the pump is in the airing cupboard, and the hot water cylinder and feed and expansion tank are in the cupboard also. the pump is a wilo, and has 5m head. i don't think the feed cistern water level is 1/3 of that above the pump! does this mean pumping over will occur? i have not had it on yet to see, but believe that 1/3 of the pump head should be met?? is this true?
thank you for your help
