I would like some advise about water pressure.
I have a gravity feed water system in a 3 bed house with a hot water cylinder in the airing cuboard. I live alone so its only one person using the stuff.
I have refitted the kitchen, ensuite and cloakroom with new taps etc.
The ensuite shower room which has a sink and a gravity feed shower. the water flow through the shower and the mono basin tap is pretty slow.( The shower and basin mono tap had a working pressure of 0.2}
The water through the kitchen taps is pretty poor ( tap is mono, but again had a 0.2 working pressure) Question also about the mono taps in the ensuite and Kitchen, I fitted isoloting valves and then connected the flexible tap tails to the isolating valves. The isolating valves were NOT full bore, but the ones with a ball and about an 8mm hole. Would these reduce pressure? because the flexi tails are small bore I did not think it would matter.
The downstairs cloakroom, the water flow is OK in the cloakroom
Im in the process of refitting the bathroom with Bath shower mixer and sink,
the old bath shower mixer water flow is fine and the 2 tap basin is good too. Do I need to go down to a 0.1 working pressure bath shower mixer
and should I stick with a 2 tap basin for better water flow?
Can I fit a pump somewhere to increase the pressure through the whole house, if so what sort of pump or should the correct taps with FULL bore Isolating valves improve what I have?
Water pressure all over the house was acceptable before I changed all the taps, I havn;t made any big changes to the plumbing.
Can anyone recommend a good low pressure bath shower mixer and basin taps that don;t cost a fortune?
