Pump not strong enough? (No, not my boiler!)
7 Aug 2008
Farndon
Hello,
Boiler:
Worcester Greenstar CDI combi boiler.
Problem:
Friend has just had complete new loft conversion, radiators are going to be fitted there, but installer says the pump on his boiler is too weak.
Solution:
Installer says the boiler must be moved to the middle floor if he wants radiators in the new loft room.
Research:
I done a bit of research and I believe that you only need a stronger pump if you have a very large house.
House type:
3 bed terraced house.
Will the boiler need to be moved?
Can you have two pumps?
Thank you.
Sounds like a builder and not a boiler engineer!
Unless there is some very special circumstances then its complete nonsense.
I dont expect he will be CORGI registered so he should not be touching boilers let alone giving incorrect advice!!
Tony
I agree, tell your friend to ignore this idiot.
Pumps in combi's are usually always the equivalent of a 15/60 so should be powerful enough unless you need about 30Kw of rads or more working off them.
I have no idea of the installer he is using but I will let him know.
How high can the pump in this boiler pump?
Pump is really a mis-used word. Heating pumps are really just circulators.
