Hi all, I know there’s a million posts on this topic but I can’t find the answer..
I have an Vailant EcoTec plus 438. It’s on an S-plan system (2x valves in airing cupboard next to cylinder) with a new wet UFH system added for the kitchen, seemingly on its own zone/system (separate thermostat/timer pump, wiring centre, etc).
Everything works fine (CH for rest of the house, HW, and UFH) except the circulating pump in the wiring cupboard before the 2x motorised valves is permanently running, even when the CH+HW and the UFH is off.
I checked the wiring in the wiring centre in the airing cupboard, nothing obviously wired incorrectly, and the valves and the cylinder thermostat are working correctly.
It just seems that the boiler is constantly running the pump. The pump overflow symbol (like a sand timer) is not displayed longer than 5 minutes after CH or HW programs are on. However, the tap icon is solidly illuminated all the time. The manual says this indicates “heating of an indirect hot water cylinder turned on”… is this normal?
I can’t for the life of me work out why the pump is running all the time. Might something be wrong with the boiler? Or is there something about how the UFH circuit was added which might have caused the circulating pump upstairs (but not the UFH pump) to run constantly, either by design or by accident?
Any suggestions gratefully received. Thankyou.
