Hello all.
Woke up this morning to much loud banging coming from the boiler.
Following an hour of stopping starting and a process of elimination I realised that the pump was not working. Confirmed after another hour or two of flushing out the system and retrying (thirty odd squid of 2 month old scale remover and water conditioner literally down the drain. grrr)
Anyhow I did the screwdriver to the ear trick and heard nothing from the pump on startup, just an electrical buzzing. Also noted that the pipe above the pump was now roasting and the pipe below was considerably colder.
Onto the problem then. I've drained the system and am in the process of removing the old pump. Needed some wd40 to free the isolaton valve union nuts up which has worked a treat. However, the isolation valve union nut seems to only spin on the side of the isolation valve (top side of nut). On the underside of the nut (the side that connects to the pump thread) I can see the thread but the nut won't undo here. The result being that the pump freely moves back and forth but won't actually undo as it can only spin about 200 degrees before coming into contact with the wall. It's a little difficult to explain in words so if i'm not making much sense let me know but i suppose what i'm getting at is shouldn't the nut be free to spin on it's own without the pump or the iso valve moving?
cheers frustrated and soon to be cold when the calor gas runs out
