- Joined
- 24 Nov 2015
- Messages
- 11
- Reaction score
- 0
- Country
a bit confused.
I have a boiler, which sends heat out via 2 valves / 2 pumps - one upstairs, one downstairs.
And also a hw send to the cylinder, a return from the cylinder with a pump on it. No valve one this one.
Problem is when the cylinder reaches temp, demand is stopped and the boiler stops central heating too. There is no zoning. All pumps are on or off.
So is it safe to disconnect the pump on the cylinder return and just use the immersion heater in the cylinder instead for Hw?
Or will the cylinder melt and explode.
The cylinder stat will still be connected and will still kill the boiler if temp is reached. So I can't see it running away.
Also, gravity fed open system.
All advice welcome.
Jack.
All advice welcome.
Jack.
