I have a gravity system and there's a pump there so I guess that it used to pump the hot water in the radiator.
Sometimes, when the heating is off, this pump keeps on pumping (and making noise) for hours. Do you know what that could be the case?
If the heating (and the hot-water) is off, surely the pump should not work... ??
This is what is on the pump:
MYSON unit fove
240v 1-50hz 0-49A 115W
code 890 U5C252
There's also another device around:
MYSON AERJEC II 0290
Also, even if that's probably irrelevant, there's two valves attached to the hot water tank:
1) SUNVIC SZ1301
2) DANTOSS RANDHILL LTD
"auto/man" switch
MK429ER TYPE HPA2
MYSON unit fove
code 890 U5C252
1) SUNVIC SZ1301
"auto/man" switch
MK429ER TYPE HPA2
