Hi
When the central heating pump starts up I can hear a whooshing sound or a running of water sound in the area of both the pump and cylinder ( both are in the same cupboard. There is one motorised valve there also which appears to be working correctly. It seems to take the cylinder longer than it should to heat up as well. There is a vertical pipe coming up off the pipe from the pump with an auto air bleed ( bottle air vale on top ) and if I remove the "tyre valve" cap and press the valve itself I get water coming out, so I suspect no air is present. Am I or could I be right in thinking the pump ( Willo Gold 60 ) is on it's last legs ? with this noise ?. I must stress that it's when the pump STARTS up that I hear it.
Many thanks in anticipation.
