I am having a problem with our boiler which is rapidly clicking and cutting out. It is an ideal classic ff380. The pump is a grundfos 16-50 (130) and this system serves 20 radiators, 70% of the radiators have trvs.
If I set the pump to 3 it rarely cycles, system gets up to temp but occasionally the boiler will rapidly click and turn off. This can be frequent which sometimes means hot water doesn't heat up correctly.
If I use pump speed 2, it doesn't click and cut out but instead it cycles a lot after being on for around 20 mins. It will cycle every 3-5 mins by turning off for around 30 seconds to a minute.
It is a 3 storey fairly new town house so I assumed with the number of radiators and 3 floors it would need to be on 3. However the same thing happens when heating hot water.
Neither setting seems ideal. Should I expect a non modulating boiler like mine to cycle like it does, if so should I leave it on speed 2?
