- Joined
- 13 Oct 2003
- Messages
- 105
- Reaction score
- 0
- Country
I'm installing a Halstead Ace high into a small house and, having done all the calcs, the pump pressure head vs flow rate is giving considerably more than is required and it is single speed, not adjustable. I know that the system will be balanced by turning down the lockshield valves so the flow rates should be as designed but is the more powerful pump likely to make the system more noisy? Would an equivalent boiler with an adjustable pump set slower be quieter?
