Hi, I have just joined this forum but have already learned much from just reading, the problem I have has baffled several heating engineers/electricians/plumbers.
The full history would take ages but I believe this is the basics of the problem.
The system is fully pumped with reliable potterton profile boiler, honeywell mid pos valve, ACL lifestyle programmer, honeywell room stat, rads stats on all radiators, etc. I think it is a single feed system for rads.
The system has been modified and added to during the last twenty years and most rads are working fine and hot water is available when needed.
One radiator has always been tricky, a bit cool, but after a lot of mucking around a new status quo has emerged.
The problem radiator gets hot, but then after an hour our two it goes off even though other rads are Very hot. I have removed the valve stat and it still stays cold.
The other problem is that even when all the system is in OFF mode, the pump sometimes runs e.g. all night.
