pump vent
30 May 2008
London
hi . is it ok to remove the pump vent on any pump? i assume if removed and water does come out then its knackered, otherwise its ok to remove?
When you say pump vent do you mean the big screw in the middle of a CH pump? Why do you want to remove it? There's nothing knackered if water comes out when you remove that, it just means that there's no air in there, which is a good thing. It's the same as if you removed the vent screw on a radiator, water comes out of that too.
