I live in a ground floor flat and i have an imersion heated in my cylinder no bolier. the pressure for my manual shower is low, can you advise me on what types of pump and bar pressure to use. Student.
I would investigate low pressure first. On a ground floor you should have enough pressure not to need pump. Could someone have turned your stopcock almost off?
