Hi
We are putting a cabin in the back of our garden and are looking to take grey waste water from a sink and shower back to the main drain of the house.
I was looking at one of these
https://www.plumbworld.co.uk/flo-force-elite-lifting-station-250w-with-2-inlets-101425-1252983
However, I'm not sure on how to do the pipe run for this. We are doing a 750mm trench which will run about 10m (with a couple of slight bends) in 20mm MDPE for mains cold water and I was intending to run the waste pipe from the above in the same trench.
Am I good to just use 32mm MDPE flexible pipe for this? I assume I need to follow the 1:100 fall off as specified, even though this makes the laying of this pipe slightly more difficult. Id rather just lay it flat along with the mains pipe if I can.
Any other suggestions on getting waste back to the house would be also a great help
