Have a customer who builds garden rooms for clients.
First one I went to, they had already done most of the plumbing install themselves.
Waste run to drain and macerator installed to supply wc, basin and shower.
Ended up with shower waste being level (if not slightly lower) than inlet to macerator, so tray filled slightly before macerator pumps water away... It was on the brink with clean water but could see it being an issue with soapy water and the eventual build up of sludge in the pipe!
Tray not able to be raised due to lower ceiling height at the rear of the construction.
They also ran the underground drain in 32mm waste pipe. Or maybe 40mm.
Moving on to the next one, they have a potential project where the drain is 40m away from the room and 3m higher!
Also, the ground where the construction is going, occasionally floods to a depth of a few centimeters as there is a failed land drain nearby.
I have been thinking about solutions...
A lifting station, outside the room, in the ground but would this be an issue with the land flooding?
A whale pump that could push waste from the tray into the macerator.
Or simply a tray with raised edges to deal with the slight back flow from tray to macerator.
Would be grateful for any input, suggestions etc.
@just pumps
@Hugh Jaleak
@HERTS P&D
Et al.
Cheers
D
@just pumps
@Hugh Jaleak
@HERTS P&D
Et al.
Cheers
D
