Hi guys I was wondering if you could help me.
I am removing my back boiler and installing motorised valves, cylinder state and a bypass valve on my oil fired heating system. The pump is on the return side of the boiler outside. I was going to to fit the vent and expansion pipes inside on the flow before everything else but am concerned this will pump over even if I make the connections less than 15cm apart as the vent will be the first thing after the boiler. They are currently on the return side. Your advice is greatly appreciated.
