Hi Guys,
Would you mind taking a listen to the below
System: Condesing boiler which heats water for a hot water tank and also a open central heating system.
the first part of the video it how i think it should sound all the time, towards the end you can hear something happening with the water like there is a large section of air in the pipes.
Had this for years but recently started to cause the boiler to stop heating the water, no flashing lights or cut outs, the green light indicating it is currently heating the water goes off, this normally happens when the water in the boiler at the time is already hot enough. Its like the pump isnt pumping the water around quick enough.
Last year our pump packed up so British Gas come out and fit a new one, I was hoping this would solve the problem but it didnt
I am also finding myself bleeding the highest radiator daily when the central heating is on.
I think we have a very strange system and I struggle to understand how it works. from the pump there is 1 pipe in and 2 out, in my mind that means 1 in is from the boiler and from the 2 out, 1 is for the central heating and the other is for hot water but they are both hot when just 1 is on (and not just hot because they are close) There is also a pipe to the hot water tank which connects to the tank for the central heating, the pipe is usually hot but when the noise starts it goes freezing cold then hot again.
Hope this makes sense!
