- Joined
- 17 Apr 2007
- Messages
- 2,540
- Reaction score
- 127
- Country
2002 1.2 8V
Had to go up to Jesmond today and recover my nephew’s car.
12.4v with meter on battery but very slow cranking. Suspected a dodgy battery cell on cranking.
Managed to start using spare and jump leads.
Hell of a wine of the alternator.
Stopped the engine, fan belt off, alternator very stiff and notchy to turn by hand. Suspected a collapsed bearing.
Belt back on, jump started engine. Now a hell of wine off starter motor for a few seconds.
Left the engine to run and all strange noises disappeared – very strange!
Got the car driven back to home base in Co Durham.
Removed the starter motor. Pinion shaft coated in friction plate dust. The dust was causing the pinion to stick in and out, hence slow crank and not disengaging straight away when engine was started.
Cleaned off with petrol. Tested starter and good as new.
Took fan belt off and alternator rotated nice and smooth so obviously a bit of crap had found its way in but now clear.
Starter back on, battery and leads cleaned up. Engine cranked and started. No strange noises.
What an exciting day!
Just needs an oil/filter/spark plugs change. Might fix speeds 1 & 2 on the heater blower as well.
By the way, if anyone needs a good little multimeter, I recommend this one!
