Hi guys was over in brothers yesterday as he called me cause his toilet wouldnt flush- but he messed around with the cable of the flush valve and a spring has come out and i cant figure out how to put it back in- its a siamp type flush valve here is a link to it- [http://www.siamp.com/index.php?option=com_hotproperty&task=view&id=53&Itemid=42]
If anyone can assist me would be very thankful, its the bottom part of the cable which is the problem where the little lever is- if you push the flusher the lever moves but has to be manually reset i need to figure out how to refit the spring so it keeps going back to original position.[/url]
