Push Button toilet
16 Jun 2007
Bedfordshire
My toilet is constantly leaking water into the bowl. It's not much but definitely leaking and as I'm on metered water I'd like to stop it. My problem is I can't take the top of the cistern off so I can have a look inside. Is there a special trick?
Well where the button is, surrounding the button there will be an outer ring-you will find this ring will unscrew until you can lift the cistern lid away from the cistern-it may be awkward if its been tightened a lot as theres not much to grip on-a pair of grips with a cloth may do it.
i am not a plumber etc. but i believe you push the button(s) down and then you can unscrew the flange bit,
your (i think) is called a flapper valve, and its quite common for them to do as yours is
Or,
you may have to remove the button to gain access to a screw retaining this whole assembly. Undo the screw and the lid will come off.
Thanks Breesey
Don't know about removing the buttons, I've got two 1/2 and full flush I think and there's no obvious way to take these out. :confused:
Aunty Rain said:
Thanks Breesey
If you push one in you should be able to remove the other. Then remove the other one (the other other one that is !!)
What make is it?
Breesey you're a genius - the little whatsits came out easy peasy. Now the fun of sorting out the leak.
Thanks :D
ps it's a Roca
