It seems a coincidence but the only few times I had to replace a push fit joint because of a leak was when I connected it to a very short run to the end of the pipe or too close to a checking valve....is that pure coincidence or maybe I'm missing an important point here? Maybe the pressure is greater at the end and so the more likely the leakage?
Would compression joints cope better in this instances?
