I have just had a new system boiler installed with plastic push fit pipework throughout. Everything seemed fine until i noticed leaks in my ceiling and walls. Managed to find the cause which was a push fit joint in the bathroom above. because the plumber that installed the system would not answer their phone, i took it upon myself to tighten the connection. The connection initially was seeping rather that gushing and managed to reduce the leakage. The walls are drying up but when i put my hand around the join it still feels moist.
Will the joint seal itself somehow or do i have to to replace the joint?
Similar scenario elsewhere in the house where suddenly a straight joint suddenly gushed out water randomly and when tighhted by hand reduced the leak. i subsequently noticed the connection to be moist and still the same when tightened with a wrench.
Any suggestions please? Is the likelihood of any other joint under the floor boards leaking aswell, that i dont know about???
