Push fit to solvent weld
20 Feb 2021
Hi all,
Got a branch coming off my soil stack which is 50mm push fit, this one,
https://www.wolseley.co.uk/product/geberit-silent-pp-875deg-branch-fitting-110-x-50mm/
And the existing kitchen waste is 40mm solvent weld, so an OD of approx 43mm.
Can anyone suggest an adapter I could use that will allow me to go from 50mm push fit to 40mm solvent weld?
I do have some 50mm pipe, this one,
https://www.wolseley.co.uk/product/geberit-silent-pp-pipe-with-one-socket-50mm-x-300cm/
So can pop a piece in so the adapter has something to go onto.
Thanks all
I'm fairly sure there's a compression adaptor for those sizes, they're a bit unsightly but will do the job.
would you happen to have a link for one?
Been searching online, been to the plumbers merchants and can't seem to find something.
Not fussed what it looks like, this is all just temporary till the kitchen gets redone then I'll redo it all properly.
The type of thing you need is like Screwfix part 69077, I realise that's the wrong size, but that is the type of fitting you need
Thanks, that was exactly what I've been looking at this morning but couldn't find one in the sizes I need.
Think I'll take a trip to a different merchants on Weds and see if they have anything there.
