HelaCon Easy
The range of push-in wire connectors are used for fast, easy and reliable connection and distribution of cable and conductors in electrical housing applications. They used within a typical range of housing voltage up to 450 volts. A huge variety of input poles allow a high flexibility in application depending of the number of conductors and available space. Diameters of up to 2,5mm² can conveniently be processed and allow the use of thicker conductors when a voltage drop occurs. The flexible fixing of the double spring of HelaCon Plus allows different conductor diameters in each entry without influencing the adjacent ones. The connectors can be used in all kinds of junction boxes either on-wall or flush mounted.
As kone was to telecoms and data, as plumbing push fits is to plumbers, will electrical connectors become push fit.
Will screw terminal products die and push fit become a standard coonector ?
HelaCon Plus
HelaCon Plus is a sophisticated push-in wire connector for professional cable connections in electrical housing applications. The newly developed double spring allows easy processing and will support installers especially in tricky situations like overhead work. This ensures proper fixing that can optically be checked through the transparent housings. Different colour codes provide a comfortable identification of the different connectors. A separate voltage test entry on the front guarantees safety during application, installation and maintenance.
Here' the main product PDF http://www.hellermanntyton.co.uk/documents/5000/HelaCon_Brochure_ENG_Jan2008.pdf
Would you or have you used them?
I've used them with certain light fittings have been supplied by them and I think there quite good.
Fantastic for over head working, converting ceiling roses to light fittings that can't retain the rose and end up on choc connectors. There's even dust / protection caps, so bye bye choc boxes, bye bye choc screw terminals
