I am trying to put a shelf up, when I came to drilling the wall the first hole was easy, but the second hole above it will only go in about 2cm and then it hits something solid, maybe metal, the wall plug is 7.5cm.
I googled it and and saw suggestions that I might be hitting a rebar and some people said that you shouldn't drill through a rebar. So do you think this is a rebar, can I drill through it and how?
