Have needed to remove all the leaded glass from our front door as the past 120 years have taken its toll and no longer fit for purpose. Followed suit of a number of neighbours and had modern leaded-looking type glass made which is pretty much single pane with adhesive lead pattern and coloured film in areas. I would have loved to commission new full authentic leaded glass but the original glass pieces were in very poor state and the cost was prohibitive.
Have removed all the old paint, treated, undercoated and top coated the door whilst no glass was in there and I now need to install the final glass but not sure if I should use a bead of silicon in before the glass, secure with pins and then putty or should I do away with the pins and putty and use a wood beading and then pin in place? Should I secure the wooden bead with another run of silicon and do away with the final pins.
When I was removing the glass the original full leaded panes were held in with various types of fixings ranging from pins, large headed tacks, screws and what appeared to be bathroom mastic!!!
