Before reading NOT to PVA freshly plastered walls prior to painting this is what i have done.... I have used a 5:1 mix of waterproof PVA, should i remove it before painting and how do i remove it.
Go over it with zinsser water based primer/sealer. Cost about £40 for a 10x10 foot room. I did my bedroom because of powdery plaster It`ll stick to and solve pretty much any problem surface.
