- Joined
- 11 Sep 2007
- Messages
- 827
- Reaction score
- 6
- Country
I've recently had to replace a broken roller keep and while doing so thought I'd address a long-standing problem where the original property owner installed the keeps a bit too low. This meant that the rollers in the door frame weren't engaging the keeps fully which sometimes caused the door to pop open if the handle wasn't pushed all the way up to engage the keeps. Even the latch wasn't engaging correctly.
So I placed the keeps a bit higher. Three went without a hitch (even the latch works fine now) but for the fourth keep I managed to drill one hole somewhat offset to one side (by about 1mm or 2). Because of the location of the old holes and the limited space I have to move the keep I can't drill another hole, and a larger diameter screw won't help either as the hole would need to be widened so much (to adjust for the offset hole) that I'd not be able to find a suitable screw with a small enough flat head for the keep.
I could leave it as it was, the other keeps are fine, but being a fussy beggar I'd like to get this last keep in the right place even though it being the odd one out won't make much difference.
So what are my options? As there is a metal frame underneath the plastic (both of which I have of course drilled through) is there any kind of really strong glue which I could use to fill up the hole in the plastic and metal frame, then re-drill it?
