PVC overflow repair
10 Dec 2008
Jersey Marine
I have a 21mm PVC overflow pipe used to provide a condensate drain.
when my boiler was replaced the guys ‘rotated’ pipe to add pipe insulation.. must have cracked/ stressed at the fitting and it has sheared off flush with the brick wall.
To avoid chiseling away brick to use a standard coupler, is there such a thing as an ‘ internal’ repair sleeve, maybe an M-F adapter.
No pressure on pipe contents, as flow is drops only.
If there is no standard fitting I will make one by putting a slit longitudinally in a 2" length of pipe and use that as an internal coupler - solvent weld in would make it water tight.
