Pyro Electrician
21 Nov 2005
London
Does anyone know of an electrician that will work on Pyro? I live in Ashford, Middlesex. Nr Heathrow Airport.
Thanks in advance.
Thanks in advance.
most electricians will know how to use pyro.
Spark123 said:
Is it imperial or something?
I couldn't tell you. It's in my ground floor Maisonette which is about 40yrs old.
The relay in the consumer unit has been tripping out periodically over the last 6 months or so.
I've had a couple of electricians look at it and they recon it needs re-wiring but it seems to me it's basically because they don't want to get involved with the Pyro.
So, before I go to the major expence and inconvenience of a re-wire, I want to get an electrician who is experienced and willing to work with with Pyro to have a look at it.
If the whole place is wired in pyro, where would a sparky start.......by insulation testing the whole lot.
It could just be a single pot bringing the install down. The circuits would need to be split into smaller sections, by disconnecting at sockets, lights etc etc.
You could then pin-point the faulty area.
If it is pyro embedded in the wall, replacing or re-terminating a pot is going to be messy!
Imperial or metric makes little odds. There are charts which give conversions of the imperial to the most appropriate metric pot/gland. Even then, a spark should be able to strip a pot down and rebuild, assuming no one has tried before, and minced the lot!
If the install is old, it may well be time for a rewire. With no further info or photos, we couldn't tell you if this is the case.
