Pyronix 46 2 keypads set 2 areas
7 Feb 2023
Hi
I have 2 keypads 00 downstairs areas A+B
01 Upstairs area A
I have all downstairs set A+B and one Pir upstairs set A only when i set from keypad 01 upstairs it wants me to exit via the exit zone 01 set final exit as should be
Can it be set up to set only area A downstairs without the timed exit that just waits for you to actually exit
Think you have set it up wrong ….normally A ….ALL …..B …..Bedtime …..so everything would be in A and B apart from anything you wanted to be off upstairs , that would be A only …but from what you are saying , you need to alter exit mode to timed or timed / final , instead of final …
Ok timed worked for setting, but changed pir upstairs to area A and when set with A it goes into alarm mode when pir sees me
Ok I was sill works after change should of set upstairs on keypad with area B for bed set it with A code and b works great
can i program a keyfob to be code and B all in one go just offer it up
Not sure what you are wanting to do ?
you can have a prox fob that can either full set only or part set only or flexi set ( you have to press a AREA button after , or you could do intelligent set where it automatically sets part until you exit by the front door ( contact ) and it changes to full set …
just sorted it Programmed a Prox fox with Area B works fine
Thanks for all your assistance
Could have just programmed the keypad to set B only. That way any code/fob that is used will initiate arming of area B only
