Hi, I've very basically installed this system but still need to set it up properly.
The booklets I find confusing. It seems to have areas ABCD rather than zones and areas don't apear to be the same thing as zones. In this case I have four PIRs and one magnetic contact. Because of the house layout I've decided to place PIRs, one each in the kitchen, living room, hall and basement. Magnetic contact is on the garage door. I use one of three different doors to come in and out of the house so I'll need to buy more contacts in the future but for now, I'm just using the alarm when going to bed.
I've put all five of the wireless detectors into area A because I haven't figured out how to set the alarm with several areas yet. It asks me which area I wish to set and I haven't figured out how to have, say A + B + C for instance. All I can get is A or B or C..
I've set the living room, kitchen and hall PIRs on 'entry route' because I have to trigger one of those at least to get to the panel.
I thought this would give a 30 second delay so I can switch it off but the alarm sounds as soon as I trigger, it's the hall PIR in this case which is my 'input 3'.
The basement and garage detectors I have set to 'intruder'. On the upside this has a great range. The garage is quite a distance from the house but shows as excellent signal strength.
I've installed a handful of wired systems over the years but the instructions for this I'm finding very complicated. Not sure if it's just me being a bit numb tbh but anyway, I haven't put the box on the wall outside yet because the neighbours won't appreciate my alarm going off every morning. For the short term the panel is loud by itself.
What am I doing wrong?
