Hello All,
Purchased the Enforcer kit 3 with digi wifi. Got it installed ok but the panel does not recognise the wifi board which is attached via a white cable block from the board to the panel. Software revision settings show V00.01 PSTN Standard. It is supposed to denote WIFI.
Within the communications settings there isn't any WIFI options or APP options, Just program ARC settings.
The WIFI board has a lit LED in the middle. The left LED intermittently flashes. Checked all connections are secured ect. Could it be a faulty board. Any help would be greatly received.
Thanks.
Thanks.
