Pyronix Euro 46 v10
3 Nov 2009
Hampshire
I moved into a property 2 years ago with this alarm installed. I know the master code.
A few weeks ago I started getting battery warnings, and then constant panel beeping. At the time I looked for the engineer code in case a reset was needed after self-replacement of the batteries, but couldn't find it (default didn't work)
Ultimately the beeping couldn't be canceled, so I powered down the entire system (the external bell only lasting for <5 minutes)
I now have a choice to a) ignore the alarm b) use the original installer for maint c) Self-manage the alarm (it's bell only) d) find an installer that will do a one-off service and reset code
I'm inclined to go for c. My issue is figuring out how to (ideally) reset the engineer code or Possibly factory reset
Any tips on this panel? I don't see any nvram reset in the manual. I've read about a possible 2 finger reset once logged in with master, but not found details.
I have exactly the same problem. Moved into a property that has a panel without the engineer or master code. I'd really like to just factory reset the board so I can start afresh and reprogramme it myself.
I can't see the NVM pins to connect together on the PCB for the reset. It's a Euro 46 v10. Can anyone give me any pointers here please?
Otherwise I'll just have to buy some other panel.
So me too. I'm getting a "control panel battery fault" message and bleeping. I can stop the bleeping for a bit. Then it returns. I've contacted the installer, but I'm waiting for a reply. Any way to silence the thing for now?
