Pyronix Nano
27 Jan 2013
Hi
I have an issue with my Pyronix Nano in that it wont fit on my bifolds main door, it needs some spacers to pack the magnetic contact out part. I can see spacers for the mini but not the nano.
Has anyone had this issue and what did they use?
I use the back door (bifold main) more than front door so its handy to have this set up same as front.
I have a PIR in the same room but not sure how well it would act as an entry/exit instead of a contact?
How well would the PIR work set up as a door contact if I cant get a spacer, Door contact would be set up as Final exit (Front and Back doors) would the PIR be the same Final exit or better as an Entry Route? I could have it pointed at the bi folds to capture entry/exit.
Would need to test if it reacts if someone on outside tho
I see what you mean the mini version…unfortunately the mini version is massive and I had this originally hence why I got the nano for the front door.
I can’t put the mini on these doors looks too unsightly.
get someone to make you spacer that has a 3d printer?
Can you provide images so that we can see what you mean by not fitting?
Security devices are for a specific purpose. If one device does not fit use another that does.
Can make any packers from perspex ?
