Hello,
I recently had a problem with my keypad on this system (one of the most frequently used rubber keys has perished) so I have begun to look for a new
keypad. Upon disconnecting the keypad i've noticed that it is connected by five wires. i have been told that if the system is 12v and 8 zone (although the paragon super is actually 6 zone) this will be compatible:
http://www.screwfix.com/p/remote-keypad/86735
Can anyone let me know if it will be please?
I had a power cut recently, the alarm rang out and would not reset until power was restored and the alarm now will not set at all using my normal code. The battery is long overdue a change so I will go ahead and do that, but can anyone work out what is causing the problem, the battery or the keypad? (or are these two separate issues?)
